search results
Hey Ray,
On the search results page, such as http://clients.motley.site/friths2/shopsearch.php?shopSearchInput=test&WADbSearch1=Search+Shop, how would I get the search term(s) added to the page here http://prntscr.com/8jm36d ? (and also add to the failed search message)
Also, if the visitor does a blank search how do you stop all products being returned?
Lastly, you mentioned in email a couple of weeks ago when you had your power cut that you would give me a bit of a steer on the search function. At the moment its seems that you can only search by words in sequence (eg 'monthly' or 'monthly disposable'). How would go about making it so that if you did a search for 'johnson
monthly' it would return any combination that has both johnson and monthly in it? You asked if I was usingthe search object and I repliedm that I wasnt sure...
Have attached the file here
Many thanks
Jamie
