mysql extention
Thread began 9/23/2015 5:56 am by natenorbie427772 | Last modified 9/23/2015 9:52 am by Ray Borduin | 274 views | 1 replies |
natenorbie427772
mysql extention
I am looking to purchase this plugin and have a question. My client wants a registration login (simple enough) however, they (the admin) doesnt want the user to actually be registered until they get an email and add the info in themselves to register that user. They then want to be able to send the confirmation request once they are approved. So essentially I need a confirmation email to go to the admin instead of the user so they can manually enter the registration and then email a confirmation. This would also require me to create a back-end admin page. Can you direct me to a tutorial and give me any insight on how to do this? Thanks!
You would need Data Bridge as well in order to send the emails.
You could create a separate admin login that allows administrators to login and approve user registrations.
It would involve probably adding two fields to the users table "UserApproved" and "UserIsAdmin". Then you could default to zero and filter in the user login based on the UserApproved column value being "1"... Admin login could do the same with the UserIsAdmin column.
Then the admin login could take the users to a list of the users identifying the ones that need approval based on the UserApproved column and have an update page where they could set the value to "1" based on a checkbox.
Emails can be sent along the way by adding the "Create Email Message" server behavior wherever appropriate (on registration and admin approval pages).
