eCart checkout page
Thread begun 9/16/2015 5:47 pm by elewis93815 | Last modified 9/17/2015 7:53 pm by Ray Borduin | 2773 views | 6 replies |
elewis93815
eCart checkout page
We've built a very simple shopping cart that submits directly to PayPal. I've built the shop page, the display and all checkout pages have been generated. the checkout.php has an additional "display" at the bottom of the page and the postal code is cutting off. Is there something done in error? I'm used to seeing this page quite differently. This page then submits to PayPal. Just making sure this is done correctly. I've also attempted to cut this entire page out to skin onto a page with the companies header and footer and I'm running into errors. Any direction would be greatly appreciated.
Do you have a url where I can see the cut off field? I think it may be a small issue in the CSS that I can help you correct, but I'll need to see the live file to properly debug it.
elewis93815
Absolutely...... www.thinflexsolutions.com/checkout.php
Can I get FTP information to debug it? It seems to be reading the height wrong and setting it wrong with the javascript. I'll have to debug the code directly to figure out why since I haven't seen this before.
elewis93815
I'll add to a private message.... Thanks so much
It was miscalculating the height I think because of the margins on the fieldset. I updated the script to fix the problem so it should work now.
elewis93815
Thanks so much!
