CSS Form Validation Effects
Thread begun 9/01/2009 4:52 am by Daryl | Last modified 9/04/2009 4:06 pm by Jason Byrnes | 7900 views | 7 replies |
DarylBeta Tester
I have just been reading the "How to" regarding adding CSS to validating form fields.
If I use this method, I assume that I need to set the redirect if failed option to the form page?
Yes, if the forms action is to post to another page, you will need to set the redirect on failure to go to the form page.
DarylBeta Tester
Thanks Jason, I thought so, but thanks for clarifying.
I have tried recreating this effect on the Log In page (made by SA) but can not seem to get it to work. I tried following a suggestion from another thread which talked about creating a recordset which checked the form field value against the database, which I think I have done. In order to do this I guess I need to create a form variable which is then used in the recordset, but I have never done this before and don't know where to put the form variable in order for it to work.
It was then suggested that I create a "Show If RS Not Blank", however I don't understand how this will work, for example;
If I create a RS that checks the form against the database (Form Field = Database Column) and the entry is there, it will output the result which would activate the show if. If the entry wasn't in the DB it would send back no date which would not activate the show if.
If I change the "Show if RS is blank" then the error shows every time I load the page.
The Login Form is from SA, I also have Validation Toolkit and lots of other WA products if the helps?
See my post in the other thread:
showthread.php?t=2740
In that thread, you are not using validation toolkit, so the method for changing the css will not apply.
DarylBeta Tester
Thanks Jason!
Is there a way to add the background css colour change to a form field for two types of validation?
The problem that I get is that I can not add two class="" to one form field.
I was thinking of adding an OR statement but can't seem to get it to work.
I have put the relevent section of code below;
<th>Retype Password:</th>
            <td><label for="pw2"></label>
              <input name="pw2" type="text" id="pw2" value="<?php echo(ValidatedField("Registration","pw2")) ?>" size="32"                            <?php
if (ValidatedField('Registration','Registration'))  {
  if ((
strpos((",".ValidatedField("Registration","Registration").","), "," . "3" . ",") !== false || "3" == ""))  {
    if (!(
false))  {
        class="errorbackground"
<?php //WAFV_Conditional Registration.php Registration(3:)
  if ((
strpos((",".ValidatedField("Registration","Registration").","), "," . "4" . ",") !== false || "4" == ""))  {
    if (!(
false))  {
                <div class="errortext">Passwords did not match</div>
<?php //WAFV_Conditional Registration.php Registration(4:)
  if ((
    if (!(
false))  {
  <div class="errortext">Please retype your password</div>
?></td>
Is this what your after:
  if ((
strpos((",".ValidatedField("Registration","Registration").","), "," . "3" . ",") !== false || "3" == "") || (strpos((",".ValidatedField("Registration","Registration").","), "," . "4" . ",") !== false || "4" == ""))  {
    if (!(
false))  {
DarylBeta Tester
Spot on!
I just couldn't figure out how to join them together.
Thanks yet again!
Cool, the key is in the middle if statement. Originaly it was:
if ((strpos((",".ValidatedField("Registration","Registration").","), "," . "3" . ",") !== false || "3" == ""))  {
To add the or to it:
if ((strpos((",".ValidatedField("Registration","Registration").","), "," . "3" . ",") !== false || "3" == "") || (strpos((",".ValidatedField("Registration","Registration").","), "," . "4" . ",") !== false || "4" == ""))  {
