Upgrading form from KFM to ckeditor
My client reported getting errors when he clicked on "browse Server" in the images properties dialog box of HTML Editor (he was trying to browse for an uploaded image). This client hadn't been in touch for some time so I had a look and realised that my copy of databridge was about two versions behind. So I updated all of my webassist suite,
I opened the file in dreamweaver and clicked on the text area that has HTML editor in place. Clicked OK and saved the file. I got some warnings about code being outside of template areas but I ignored that. I uplaoded the file and get this error
Fatal error: Class 'CKEditor' not found in /home/cvmorguk/public_html/admin/news/news_items/news_Insert.php on line 229
I did upload the ckeditor folder by the way.
Any ideas? I've attached the file in question.
Many thanks,
John
EDIT: This was the original error messages
Strict Standards: Redefining already defined constructor for class DB in /home/cvmorguk/public_html/HTMLEditor/editor/plugins/kfm/includes/db.php on line 18
Strict Standards: Redefining already defined constructor for class kfmSession in /home/cvmorguk/public_html/HTMLEditor/editor/plugins/kfm/includes/session.class.php on line 33
Strict Standards: Redefining already defined constructor for class kfmDirectory in /home/cvmorguk/public_html/HTMLEditor/editor/plugins/kfm/includes/directory.class.php on line 15
Warning: session_start(): Cannot send session cache limiter - headers already sent (output started at /home/cvmorguk/public_html/HTMLEditor/editor/plugins/kfm/includes/db.php:18) in /home/cvmorguk/public_html/WA_SecurityAssist/Helper_PHP.php on line 5
Strict Standards: Declaration of MDB2_Driver_Common::raiseError() should be compatible with & PEAR::raiseError($message = NULL, $code = NULL, $mode = NULL, $options = NULL, $userinfo = NULL, $error_class = NULL, $skipmsg = false) in /home/cvmorguk/public_html/HTMLEditor/editor/plugins/kfm/includes/pear/MDB2.php on line 990
Strict Standards: Non-static method MDB2::connect() should not be called statically in /home/cvmorguk/public_html/HTMLEditor/editor/plugins/kfm/initialise.php on line 176
Strict Standards: Non-static method MDB2::factory() should not be called statically in /home/cvmorguk/public_html/HTMLEditor/editor/plugins/kfm/includes/pear/MDB2.php on line 433
Strict Standards: Non-static method MDB2::parseDSN() should not be called statically in /home/cvmorguk/public_html/HTMLEditor/editor/plugins/kfm/includes/pear/MDB2.php on line 376
Strict Standards: Non-static method MDB2::loadClass() should not be called statically in /home/cvmorguk/public_html/HTMLEditor/editor/plugins/kfm/includes/pear/MDB2.php on line 385
Strict Standards: Non-static method MDB2::classExists() should not be called statically in /home/cvmorguk/public_html/HTMLEditor/editor/plugins/kfm/includes/pear/MDB2.php on line 327
Strict Standards: Non-static method PEAR::isError() should not be called statically in /home/cvmorguk/public_html/HTMLEditor/editor/plugins/kfm/includes/pear/MDB2.php on line 386
Strict Standards: Non-static method MDB2::parseDSN() should not be called statically, assuming $this from incompatible context in /home/cvmorguk/public_html/HTMLEditor/editor/plugins/kfm/includes/pear/MDB2.php on line 2298
Strict Standards: Non-static method MDB2::setOptions() should not be called statically in /home/cvmorguk/public_html/HTMLEditor/editor/plugins/kfm/includes/pear/MDB2.php on line 392
Strict Standards: Non-static method PEAR::isError() should not be called statically in /home/cvmorguk/public_html/HTMLEditor/editor/plugins/kfm/includes/pear/MDB2.php on line 393
Strict Standards: Non-static method PEAR::isError() should not be called statically in /home/cvmorguk/public_html/HTMLEditor/editor/plugins/kfm/includes/pear/MDB2.php on line 434
Strict Standards: Non-static method PEAR::isError() should not be called statically in /home/cvmorguk/public_html/HTMLEditor/editor/plugins/kfm/includes/pear/MDB2.php on line 439
Strict Standards: Non-static method PEAR::isError() should not be called statically in /home/cvmorguk/public_html/HTMLEditor/editor/plugins/kfm/initialise.php on line 177
Strict Standards: Non-static method MDB2::classExists() should not be called statically, assuming $this from incompatible context in /home/cvmorguk/public_html/HTMLEditor/editor/plugins/kfm/includes/pear/MDB2.php on line 2567
Strict Standards: Non-static method MDB2::isResultCommon() should not be called statically, assuming $this from incompatible context in /home/cvmorguk/public_html/HTMLEditor/editor/plugins/kfm/includes/pear/MDB2.php on line 2573
Strict Standards: Non-static method PEAR::isError() should not be called statically in /home/cvmorguk/public_html/HTMLEditor/editor/plugins/kfm/initialise.php on line 33
Strict Standards: Non-static method PEAR::isError() should not be called statically, assuming $this from incompatible context in /home/cvmorguk/public_html/HTMLEditor/editor/plugins/kfm/includes/pear/MDB2.php on line 3555
