Single Sign-on for Web Assist Admin Sites
Thread begun 9/09/2015 7:45 am by mrobben375515 | Last modified 9/09/2015 10:25 am by Ray Borduin | 567 views | 1 replies |
mrobben375515
I have multiple admin sites for the WA admin tools PowerMessanger, PowerGallery, CMS, and eCart6. I want to build 1 portal for my client to login to and from there they can access any of the admin tools, given that they have user access. One thought is to create a user table and put in a URL single sign-on string that will log the user in. Will that work and if so, what would that string build be? Do you have any other suggestions on accomplishing this?
I am also concerned about syncing the multiple user tables. Can all the WA tables point to 1 user table and 1 customer table? Should I ask this under a new thread?
You can use a single users table and do single sign in... but it might be a little tricky to update the login page. I think the easiest way to do it would be to eliminate all of the login pages but one, then update that remaining page to set all of the session variables that would have been set if you logged into all of the admin pages separately. That would accomplish the single sign in for admin.
Then probably using the PowerMessenger users table would be the most appropriate because I think it has a few extra columns you need for that application. You could remove the registration, insert, and update pages for the other users tables and then make sure you don't refer to them in other pages.
