Why is the form not sending when submit is pressed?
Thread begun 9/07/2015 10:24 pm by michaelf0199272 | Last modified 9/08/2015 4:29 pm by Ray Borduin | 3372 views | 8 replies |
michaelf0199272
http://www.omoyorubadfw.org/membership-applicationwoo.php
when the membership form is filled out and sent --- no email is received at the designated emails.
Q: Any idea why this is happening?
I don't see a problem with this page. Can I see a copy of the page: webassist/email/waue_membership-applicationwoo_1.php
Maybe it is where the issue is.
Are you on your live server when testing? What did you set as the FROM address? Are you sure it isn't sending but being placed in the SPAM folder?
One good way to test is to add a session dump to the page like:
@session_start();
var_dump($_SESSION);
That will let you check to see if the page settings are set to the values you would expect and if it "thinks" the email was sent correctly.
michaelf0199272
@session_start();
I have attached the file for your review.
michaelf0199272
where should I place
@session_start();
You can add it to the body of the page that is displayed after the form submits.
michaelf0199272
ok --- let me try it. thanks
michaelf0199272
there were no dump. only the thank you page loaded.
michaelf0199272
you are right it went into the junk box. but there is a problem --- none off the "filled in" data showed of the email/report. In the attached image you will see what came through.
Your form elements don't have name="" attributes. You need to add a name for the form elements for them to work properly.
