Error when attempting to add an ecart object
Thread begun 9/07/2015 3:11 pm by elewis93815 | Last modified 9/08/2015 11:05 am by Ray Borduin | 1412 views | 4 replies |
elewis93815
While executing timer in WA eCart Object.htm, the following JavaScript error occurred:
At line 79 of file
"C:Users/Sarai/AppData/Roaming/Adobe/Dreamweaver CC2014.1/en_US/Configuration/Shared/WebAssist/eCart/WA eCartShared.js":
wa.pickDLL is not function
Also, I originally attempting to build this cart on my primary computer that uses Dreamweaver CC2015. I had eCart installed on this computer by Adobe. eCart does not show on any of my WebAssist tabs, however, does show in "Insert" but when I scroll down to WebAssist - eCart - it does nothing. Any thoughts on this? It almost appears that it really didn't install?
Yes, please reinstall the latest version and this error should go away. The installation looks old and/or incomplete.
elewis93815
Thank you,I'll give that a try!
elewis93815
Hello Ray,
I have re installed the latest version and still no luck. I just got off a remote chat with Adobe trying to get eCart to work. I've attached the most recent error that I'm getting in hopes that you can guide me to a possible problem.
It looks like you are running an older version of eCart on a newer version of Dreamweaver. You are going to have to upgrade to eCart 6 for it to work in Dreamweaver CC.
