My upload is not working - I get an error that "The requested URL /FaithCentre/OnlineStore/uploader.php was not found on this server." There is an include placed at page top that correctly paths: <?php require_once("../webassist/file_manipulation/hel
Thread begun 9/07/2015 9:58 am by randyrie405335 | Last modified 10/05/2015 1:18 pm by Ray Borduin | 2770 views | 4 replies |
randyrie405335
Upload is not Working
My upload is not working - I get an error that "The requested URL/xxx/xxx/uploader.php was not found on this server." However, there is an include placed at page top that correctly paths: <?php require_once("../webassist/file_manipulation/helperphp.php"); ?> and the file does exist in the Webassist/File Manipulation folder.
Page is attached for your review. Have your July, 2015 updates flopped? I'm having trouble with nearly all of your extensions in Data Bridge and MySQLi since I've updated.
Your form action is set to post to a page called "uploader.php"... maybe that was an old page you were using?
<form action="uploader.php"
just remove that in your form and it should submit to itself like:
<form action=""
What issues are you having with the updates? If you are more specific I can help you with them.
The trigger dropdown list can be used for common triggers. Only use the lighting bolt if you are an advanced user that is doing something special.
randyrie405335
I cleared the form action value and now the upload works... what inserted this value in the first place?
On another note, this same page has an update server behavior which includes an HTMLEditor function. The update does not work (it did before I added the upload capability) and I don't believe I've changed anything but remove the form action value to <form action="" ...> Can you see what is preventing the update behavior from working? One question: I'm using your HTMLEditor from the DataBridge extension and the DWCS6 legacy update behavior. Should I be using the MYSQLi update behavior instead of Adobe's legacy behavior or are the two behaviors OK together?
I'm attaching the updated webpage.
Changing the action on a different form definitely wouldn't break it.
You can use MySQL and MySQLi side by side even on the same page.
I see you have your table in a repeated region... I think you need to move your form tag and hidden elements into the repeated region as well for that to work, so move line 131 down below 132 and move lines 219-221 up above 218.
You have a repeat region wrapped around the table, but not the form. That is preventing the update from working.
If you want to allow update of individual rows you would have to wrap the repeat region around the entire form. If you are only updating one row from this page, then you should remove the repeated region server behavior entirely.
