What's the point of " $editFormAction "
Thread begun 9/05/2015 11:04 am by Steve | Last modified 9/07/2015 12:13 pm by Ray Borduin | 1778 views | 1 replies |
Steve
On an older site , I updated some Insert routines and started getting an error...
Eventually, I traced it to the form and the undefined variable: $editFormAction
Example:
<form id="form1" name="form1" method="POST" action="<?php echo $editFormAction; ?>">
Removing the reference in the form action solved the problem but I wonder what the point of this is?
I searched out some older documents and see the following defines the variable:
$editFormAction = $_SERVER['PHP_SELF'];
if (isset($_SERVER['QUERY_STRING'])) {
$editFormAction .= "?" . htmlentities($_SERVER['QUERY_STRING']);
Is it deprecated? Or is it just used to reload the same page on post?
Dreamweaver uses that code to submit to the same page. It can be removed and just use action="" which should do the same thing.
