Multiple Dynamic Options....
Thread begun 9/04/2015 4:43 am by codamedia | Last modified 9/04/2015 10:17 am by Ray Borduin | 881 views | 1 replies |
codamedia
I've read both the "dynamic options" tutorials... and although they work perfectly fine - they are not what I would call dynamic. Sure - the options can be added to the database, but each option "name, price diff and weight diff" needs to be manually added to the eCart Object in order to be recognized.
So - rather than manually setting up color(text), size(text), sizePriceDiff, sizeWeightDiff, colorPriceDiff etc... I figured - why not create re-usable containers in the eCart Object that all options can use. That way the the option is truly dynamic and can be any name and price change as needed.
So far, so good.... now the problem.
Even if I have 3 or 4 options on a product, only one of those (the last one) makes it to the containers in the eCart Object
Is there another tutorial I am missing? If not - would I do this using arrays, or is there an easy solution I am overlooking?
codamedia
Quick update to say I have solved this problem...
1: From the product page, Option ID's are submitted as an array
2: I "implode" the Array, and use that (with IN) for my option value lookup
3: My option value lookup sums the prices differences to a value, and sums the weight differences to a value
4: Option names are saved as a comma list.
In the eCart Object there are just three containers that hold all the necessary data.... Name (which takes the comma list from #4), priceDiff, and weightDiff.... both from the calculations in #3.
The benefit of this method is that you don't have to create an eCart Object for each option... It allows for unlimited options per product, and all options can be managed from the database alone.
If there is a caveat to this that I am missing, please feel free to point it out. Or.... if there was an easier method that I overlooked - I'm open to that as well!
