canada post and fedex not working
Thread begun 9/03/2015 1:20 pm by stuff223820 | Last modified 9/29/2015 12:20 am by Ray Borduin | 4754 views | 21 replies |
stuff223820
i have tried to get fedex and canadapost to connect and show as a shipping option. I got UPS to work but not the others. i set up multiple rules to try and get options but no go. The only way to get canadapost to work is to manually set CanadaPost as a "Custom" provider and manually set rules. Please help
Can you give me FTP access to the site so I can test and try to figure out why it isn't working?
stuff223820
info as requested. Thanks Ray. Could be a permissions error again?
See private message
stuff223820
thanks
I entered a canada address and got canada post options. What address were you using that didn't work?
stuff223820
Hi Ray
The canada post options in the drop down at shipping stage are only 2 of several custom rules that i created. None of which seem to actually connect to Canadapost for a weight based rate.. am i missing something? Only UPS seems to connect ok and gets an actual dynamic rate
I appreciate your help with this! it is my only holding point now from launch
You can also see many other custom canada post rules i set which do not trigger at all.
The canada post issue appears to be API credentials as well. Where did you get the credentials? Can you send me a screen shot of the credentials from the Canada Post site? I may be able to see what is wrong.
stuff223820
Hi RAY - see enclosed
It looks like they also require a "customer number" and "contract id" in their new api. Do you have values for those as well?
