Nested Repeat By Date
Thread begun 9/03/2015 12:36 pm by eric284736 | Last modified 9/03/2015 4:12 pm by Ray Borduin | 1589 views | 4 replies |
eric284736
Hi Jason,
I am trying to setup a nested repeat by dates.
Example:
The main category pulls the dates from the product table by month and year.
SELECT YEAR(DateAdd) AS 'year', MONTH(DateAdd) AS 'month'
FROM VideoDictionary
GROUP BY year, month
ORDER BY year DESC, month DESC
So this will list the most recent 12 month entries as Month/Year
Now the nested repeat will pull the new products that were added within the relative Month/Year.
SELECT vdID, DateAdd, vidcateID, Title, Photo, Display
WHERE Display = 1 AND DateAdd = colname
GROUP BY DateAdd DESC
Is this correct?
thx
Eric
WHERE Display = 1 AND YEAR(DateAdd) = yearparam AND MONTH(DateAdd) = monthparam
eric284736
Thanks Ray!
I am almost there :)
Here is the code I have in place, but I think I may be missing something.
$maxRows_rsMonths = 12;
$pageNum_rsMonths = 0;
if (isset($_GET['pageNum_rsMonths'])) {
$pageNum_rsMonths = $_GET['pageNum_rsMonths'];
$startRow_rsMonths = $pageNum_rsMonths * $maxRows_rsMonths;
mysql_select_db($database_connBLUR, $connBLUR);
$query_rsMonths = "SELECT YEAR(DateAdd) AS 'year', MONTH(DateAdd) AS 'month' FROM VideoDictionary GROUP BY year, month ORDER BY year DESC, month DESC";
$query_limit_rsMonths = sprintf("%s LIMIT %d, %d", $query_rsMonths, $startRow_rsMonths, $maxRows_rsMonths);
$rsMonths = mysql_query($query_limit_rsMonths, $connBLUR) or die(mysql_error());
$row_rsMonths = mysql_fetch_assoc($rsMonths);
if (isset($_GET['totalRows_rsMonths'])) {
$totalRows_rsMonths = $_GET['totalRows_rsMonths'];
} else {
$all_rsMonths = mysql_query($query_rsMonths);
$totalRows_rsMonths = mysql_num_rows($all_rsMonths);
$totalPages_rsMonths = ceil($totalRows_rsMonths/$maxRows_rsMonths)-1;
// RepeatSelectionCounter_1 Initialization
$RepeatSelectionCounter_1 = 0;
$RepeatSelectionCounterBasedLooping_1 = false;
$RepeatSelectionCounter_1_Iterations = "12";
// RepeatSelectionCounter_2 Initialization
$RepeatSelectionCounter_2 = 0;
$RepeatSelectionCounterBasedLooping_2 = false;
$RepeatSelectionCounter_2_Iterations = "-1";
$page_title = $row_rsMeta['title'];
$page_description = $row_rsMeta['description'];
<?php include("_header.php"); ?>
<section class="row pagebound">
<!-- content -->
<div class="row">
<div class="large-12 columns">
<h1><img src="assets/icons/icons-green11.png"/> Video Library New Releases</h1>
</div>
</div>
<div class="row">
// RepeatSelectionCounter_1 Begin Loop
$RepeatSelectionCounter_1_IterationsRemaining = $RepeatSelectionCounter_1_Iterations;
while($RepeatSelectionCounter_1_IterationsRemaining--){
if($RepeatSelectionCounterBasedLooping_1 || $row_rsMonths){
<h2> <?php echo $row_rsMonths['month']; ?>/<?php echo $row_rsMonths['year']; ?></h2>
$yearparam_rsVideo = "-1";
if (isset($_GET['DateAdd'])) {
$yearparam_rsVideo = $_GET['DateAdd'];
$monthparam_rsVideo = "-1";
$monthparam_rsVideo = $_GET['DateAdd'];
$query_rsVideo = sprintf("SELECT vdID, DateAdd, vidcateID, Title, Photo, Display FROM VideoDictionary WHERE Display = 1 AND YEAR(DateAdd) = %s AND MONTH(DateAdd) = %s ORDER BY DateAdd Desc", GetSQLValueString($yearparam_rsVideo, "int"),GetSQLValueString($monthparam_rsVideo, "int"));
$rsVideo = mysql_query($query_rsVideo, $connBLUR) or die(mysql_error());
$row_rsVideo = mysql_fetch_assoc($rsVideo);
$totalRows_rsVideo = mysql_num_rows($rsVideo);
$_GET['DateAdd'] = $row_rsMonths['DateAdd'];
// RepeatSelectionCounter_2 Begin Loop
$RepeatSelectionCounter_2_IterationsRemaining = $RepeatSelectionCounter_2_Iterations;
while($RepeatSelectionCounter_2_IterationsRemaining--){
if($RepeatSelectionCounterBasedLooping_2 || $row_rsVideo){
<div><?php echo $row_rsVideo['Title']; ?></div>
} // RepeatSelectionCounter_2 Begin Alternate Content
else{
<?php } // RepeatSelectionCounter_2 End Alternate Content
if(!$RepeatSelectionCounterBasedLooping_2 && $RepeatSelectionCounter_2_IterationsRemaining != 0){
if(!$row_rsVideo && $RepeatSelectionCounter_2_Iterations == -1){$RepeatSelectionCounter_2_IterationsRemaining = 0;}
$RepeatSelectionCounter_2++;
} // RepeatSelectionCounter_2 End Loop
</div>
} // RepeatSelectionCounter_1 Begin Alternate Content
else{
<?php } // RepeatSelectionCounter_1 End Alternate Content
if(!$RepeatSelectionCounterBasedLooping_1 && $RepeatSelectionCounter_1_IterationsRemaining != 0){
if(!$row_rsMonths && $RepeatSelectionCounter_1_Iterations == -1){$RepeatSelectionCounter_1_IterationsRemaining = 0;}
$RepeatSelectionCounter_1++;
} // RepeatSelectionCounter_1 End Loop
Inside the outer loop you need to define the parameters for the internal recordset to come from the main recordset. So instead of:
$yearparam_rsVideo
"-1";
if (isset(
$yearparam_rsVideo $_GET['DateAdd'];
$monthparam_rsVideo "-1";
if (isset(
$monthparam_rsVideo $_GET['DateAdd'];
mysql_select_db($database_connBLUR$connBLUR);
$query_rsVideo sprintf("SELECT vdID, DateAdd, vidcateID, Title, Photo, Display FROM VideoDictionary WHERE Display = 1 AND YEAR(DateAdd) = %s AND MONTH(DateAdd) = %s ORDER BY DateAdd Desc"GetSQLValueString($yearparam_rsVideo"int"),GetSQLValueString($monthparam_rsVideo"int"));
$rsVideo mysql_query($query_rsVideo$connBLUR) or die(mysql_error());
$row_rsVideo mysql_fetch_assoc($rsVideo);
$totalRows_rsVideo mysql_num_rows($rsVideo);
$_GET
you would use:
$_GET
['yearAdd'] = $row_rsMonths['year'];
$_GET['monthAdd'] = $row_rsMonths['month'];
$yearparam_rsVideo
"-1";
if (isset(
$_GET['yearAdd'])) {
$yearparam_rsVideo $_GET['yearAdd'];
if (isset(
$_GET['monthAdd'])) {
$monthparam_rsVideo $_GET['monthAdd'];
eric284736
Perfect! That works - THANKS Ray!
