Different email address depending on dropdown
This post has been deleted.
Your code is using angled quotes instead of standard double quotes. That could be the issue.
also you shouldn't have that extra space inside the brackets. So for instance:
case “1”:
$RecipArray[$CurIndex ][] = “beavers@x.org.uk”;
should be:
case "1":
$RecipArray[$CurIndex][] = "beavers@x.org.uk";
