Sub menu in front of main menu drop downs
Thread begun 8/31/2009 10:13 pm by Russell Collins | Last modified 9/02/2009 10:56 am by Jason Byrnes | 2864 views | 3 replies |
Russell CollinsBeta Tester
I have a horizontal main menu.
I have a sub menu in the left column.
When using the main horizontal menu the sub menu remains in front so you can't see the dropdowns.
Any Ideas ?
Regards
Russ
In the menu.css for the top menu, add:
position: relative;
z-index: 9999;
to the first selector to give the top menu a higher stacking order than the side menu.
Thanks very much Jason,
That worked a treat.
But for the sake of clarity for others with the same issue there was a typo in the code snippet. There was a semicolon after position, should be colon!
position: relative;
z-index: 9999;
Regards
Russ
Sorry about the typo Russel, I have fixed it in my original post.
