Log In Behavior accepts everything
Thread began 8/30/2015 12:37 pm by Sarre | Last modified 9/01/2015 10:03 am by Ray Borduin | 799 views | 2 replies |
Sarre
I have spent the weekend trying to implement WA Mysqli Server Behavior - log in function, but keep running into problems. The log in function accepts everything, blank fields, wrong usernames, you name it. Funny thing is, when I log out and try to go back to a restricted page, I am blocked.
I have not altered any code, no blank fields in the db and every connection works fine. Working locally with CS6 and XAMPP.
Regards,
Chris
It doesn't look like you have specified anything in the "Find" record tab. That is what is used to find and restrict access based on the username and password fields. You need to edit the server behavior and map the username and password columns to find the values based on your form elements.
Sarre
Ok, the "Find"-function was a little unclear to me for some reason.
For other users, I set names to the textfields in the login form and when using the "Find" record tab these names can be attached to the login function.
Thanks for helping out, Ray!
