image upload problem
Hey Ray
Am getting this error when trying to upload an image: http://prntscr.com/86sipp
Have attached the image in question plus the insert page.
Other images are being uploaded fine so not sure why this one wont?
Cheers
Jamie
Hey Ray
Cheers
Jamie
This is a pretty large file. Are you able to upload other images of this size? I'm thinking your upload_max_filesize or post_max_size may be set to low preventing the upload?
What happens if you remove the resize settings? The error is in the resize code, but I'm thinking the resize is failing because the file upload may be failing to begin with. Can you get the file to upload without resize?
