Search bar on home page won't work
I have a search bar on each page but the search on the home page won't work. It works on all the other pages. What have I done wrong on the home page?
The home page is www.prowaterparts.com
Thanks!
Thanks!
Try moving the progress bar jquery code below the other jquery include... so move this:
<script src="http://www.prowaterparts.com/webassist/progress_bar/jquery-blockui-formprocessing.js" type="text/javascript"></script>
to just before the </head> tag... that may work.
Can I get FTP access. I'm thinking it is some sort of conflict with the other JQuery version you are using for the slideshow, but I'll have to debug to find the best solution.
The login information you provided doesn't seem to work. Please review it and post back and I will try again.
It still gives me an error that the password is not correct and I can't access the FTP
I was able to get in and fix the problem. It appears the progress bar code depended on having the jquery library .js file on the page. It is added by form builder, that is why it is usually there. I've updated the webassist/progress_bar/jquery-blockui-formprocessing.js file on your server so that it will work without the jquery library and I'll make the update in Data Bridge for the next bug fix release.
