Something is fishy with DIV tags and form
Thread begun 8/31/2009 5:21 pm by chris384639 | Last modified 9/08/2009 1:30 pm by Jason Byrnes | 5388 views | 8 replies |
chris384639
index2.php
The form is only showing 1 field and stopping there. Can you take a look at this?
Thanks!
Looks like a PHP error is occurring that is causing the page not to render completely.
add the following at line 1 to turn on error reporting:
error_reporting
(E_ALL);
chris384639
Not sure what you mean- what file do I paste this code in?
The index.php file at line 1.
chris384639
Same results... here's my code:
In the page you have sent, you have removed all of the origianl code that is in the head of the document before the doctype tag, that code must be in place before the doctype tag.
chris384639
Sorry- I've been out of town and am back. Please check out the page.
Thanks!!
index2.php
chris384639
Hold off on looking at the code- I just signed up for the monthly program and see there is another extension.
When I submit the form on the page you provided, I see a blank white page. This means a PHP error has occured. Add the code:
error_reporting
(E_ALL);
to line one to turn on error reporting.
