showing number of results
Thread begun 8/18/2015 6:26 am by Jamie | Last modified 8/18/2015 10:43 am by Ray Borduin | 668 views | 1 replies |
Jamie
Hey Ray
On this page, I have a 'filter' set up for 'Brand' and also for 'Type' - http://prntscr.com/860ynl
I am trying to get them to show within the () the number of products that are available within that 'set'. For example, if you click on Weekly Disposables, there are no products but within the () is 5 - it seems that what I have done so far is just showing the number of 'filter options' that are available (excluding the 'all')
Have attached the main file plus the 2 includes that run the brand and type content.
As you can see, the brand section is being populated by the recordset 'ManufacturerBreadcrumbs' while the type is being populated by 'TypeBreadcrumbs' - clearly I have got it set up incorrectly but not sure how I go about achieving what I am trying to.....
Jamie
I couldn't find the SQL statements for those two recordsets on any of the pages. However I see you are using the TotalRows property of the recordset to get the count, and that won't work because it is the number of rows in that recordset.
You probably have to adjust the SQL and use some nested SELECT Count() statements or even separate recordsets to get the row count inside the repeat region, which may be more efficient.
