New Mac - WebAssist crashes Dreamweaver
Thread begun 8/17/2015 3:21 pm by AdamG | Last modified 8/18/2015 10:13 am by Ray Borduin | 1291 views | 2 replies |
AdamG
I have a new iMac. Migrated all apps from the old to the new. WebAssist tools required my serial numbers, so I added them as needed. Quit Dreamweaver, then re-launched. Nothing worked so I remove ALL extensions (WebAssist and all others), uninstalled DW, reinstalled DW. I did NOT install any extensions. Upon launching DW, I get this message:
Unable to find file WA_SiteTools_ProgressV2.htm in the Configuration / Floaters directory. The floater will not be shown.
I deleted everything I could find relating to WebAssist and I'm still getting error messages, such as "Unable to open script file "/Applications:Adobe Dreamweaver CS6:Configuration:WA_Installer:Library2:WA_Configuration.js" (error 2). Yikes.
How much code do I have to find, and can you help me uninstall everything so I can re-install it and get it working?
Just rename the local user configuration folder and it will remove all remnants of any extensions left behind.
The floater error may persist. To get rid of that go to Window->Workspace Layout->Reset 'your layout'
AdamG
Problem solved. Thanks.
