email form works, but not when put into a bootstrap modal
Thread begun 8/14/2015 11:04 am by Sweens | Last modified 8/15/2015 11:51 pm by Ray Borduin | 2603 views | 3 replies |
Sweens
HI
I hope you can help with this - but I don't think it's really a web assist issue, rather bootstrap!
The attached shows two pages that are basically the same; MailMember.php is called in a new window; mail sent from this page is sent successfully,
I copied this code, as a starting point, into a bootstrap modal (modal-Mailmember.php); the modal opens and the form is displayed, together with dynamic values - but no email is sent.
I have no idea what is causing the conflict and hope you may be able to help
Cheers
Chris
I see you have a redirect set for the update server behavior that happens before the email. Try removing the redirect from the update and put it in the email server behavior instead.
Sweens
Thanks Ray
Already tried that - removed the server behaviour completely and the second submit button - set the email to trigger on btSend pressed (in attachment), but still no joy!
Cheers
Chris
You are trying to send the email to the Recordset result based on a URL parameter that isn't passed forward through the form submit.
Change your form action to: action="modal-MailMember-1.php?MemID=<?php echo(intval($_GET['MemID'])); ?>"
and it should fix that problem.
