Email not sending due to new domain extensions
Thread begun 8/12/2015 3:11 am by Dooza | Last modified 11/12/2015 10:50 am by Ray Borduin | 3011 views | 7 replies |
Dooza
Hi there,
I have a problem with the Classis ASP version of this extension that has been working nicely up until now. The problem is an email address using the a new domain extension .scot
There are hundreds of new ones and they will soon start to be a big problem for all users of Universal Email. The function WAUE_isEmailAddress needs to be updated to handle them all.
I know its an old extension but I am hoping the promise of continued support holds true.
Cheers,
Steve
If you attach a copy of the page where the WAUE_isEmailAddress function is defined I can walk you through updating it.
Dooza
Hi Ray,
Here you go. I figured out that I can add the domain extension to a list of good ones, and that worked nicely. I then realised I was going to have to add 700 to this list, which wasn't going to work. As a temporary fix I found that part that checks the length of the extension and the known addresses, and commented out the part that makes it return false.
If there is a better way to do this I am all ears :)
Cheers,
Steve
I think what you did is probably the best solution... comment out lines 76-78
That is the section that checks against the list of known domains, and with 700 being added, you probably are better off just not doing that check any more.
Dooza
Hi Ray,
This is what I thought too. I will update the file in all the sites that use it.
One day we will have domain extensions that we make up rather than choosing from a list.
Cheers,
Steve
Mags
On the same subject, I have this issue with someone who is using a .solutions email address. Adding that TLD to the allowed domains in the mailformatting_php.php file works fine, BUT whenever I add a new email behavior or update an existing one, that file is updated automatically and my changes are removed. This means I always have to remember to manually add that TLD back in.
Commenting out the lines to prevent checking sounds like a great idea, however would the same thing happen i.e. the change would be overwritten whenever an update is made? Is there any way to prevent this?
Yes, you can update the file in your Dreamweaver users configuration folder: /Configuration/Shared/WebAssist/FormValidations/Scripts/WAVT_Scripts_PHP.php
If you update the file there it will use that file when applying on new sites.
Mags
Many thanks for the tip!
