How to build a search form
Thread began 8/11/2015 2:26 pm by LionsMane | Last modified 9/02/2015 10:47 am by Ray Borduin | 702 views | 5 replies |
LionsMane
I've got a basic search form working when a user enters either an appropriate uniqueID for a record, or for a different identifying column. The problem I'm having is that the client ALSO wants to add to this form two date fields, so a user could also search between two dates, along with the other values, or by the date range alone. How can I modify this select statement to try and get it to work?
$Results->setQuery("SELECT * FROM Reservations WHERE (RID LIKE ? OR Type LIKE ?) ORDER BY RID");
Are all of the fields required?
I think you are probably going to have to manually update your recordset code to make it truly dynamic and update the SQL statement and passed parameters based on what form fields have been filled out.
This is something we could help with in a premier support ticket.
LionsMane
Premier support
Thanks Ray, so how much does this cost me, and what's the turnaround? Thanks
We can do it in a single support session for $99.99... We can usually accommodate next-day scheduling when a request is submitted.
LionsMane
next steps
More info in the PM
Just go to this page: http://www.webassist.com/premier_request.php and we will contact you to schedule the appointment.
