eCart Checkout Wizard - not asking for a delivery address?
Thread begun 8/11/2015 6:43 am by Nathon Jones Web Design | Last modified 8/12/2015 10:45 am by Ray Borduin | 3498 views | 6 replies |
Jeez. So I took the plunge and ran the eCart Checkout Wizard, albeit I had no hopes of it working!
Sure enough, it's asking for a billing address but it doesn't ask for a delivery address. :(
Here's how to replicate this. Go to the following page and add this item to basket:
http://www.nathonjoneswebdesign.co.uk/whiskybroker/buy-whisky-online-Scotland.php?wbid=3
Then return to the home page (http://www.nathonjoneswebdesign.co.uk/whiskybroker/) and click the "Checkout" button in the quick cart (top right). Enter your billing address (it doesn't allow you to enter a UK telephone number) and when you click continue you are simply asked to then submit payment. It doesn't ask for any delivery address information which makes calculating the shipping rate impossible.
Hope you can help. Thank you.
NJ
EDIT: I should add that we are able to submit the Billing Address, for all the good it will do, to Sage Pay but after initially receiving an error on the URLwhich eCart Checkout Wizard installs by default - https://test.sagepay.com/Simulator/VSPFormGateway.asp - we contacted Sage Pay and they told us that the URL should actually be https://test.sagepay.com/gateway/service/vspdirect-register.vsp
After fixing that and submitting we get the following error:
VPSProtocol=2.23 Status=MALFORMED StatusDetail=3055 : The CardType field is required.
CardType? We're not asking the customer to enter their card details.
There is also the issue, though, of eCart not installing the Delivery Address form. It's all extremely odd and we'd appreciate some clarification on it.
Thank you.
There is a checkbox in the checkout wizard for "Include shipping fields on checkout page"
It should always create the shipping fields as long as that checkbox is checked, the checkout form you have seems to be what would result if that checkbox was not checked.
The url they gave you is for direct pay api, which requires the card details to be passed in.
Looking through their documentation, it appears the original url the eCart used was correct, but you might try:
https://test.sagepay.com/gateway/service/vspform-register.vsp
The url should definitely not be the vspdirect version if you aren't asking for credit card details from your site.
I'll double check that. I don't recall that checkbox but I don't doubt it's there!
  Looking through their documentation, it appears the original url the eCart used was correct...
SagePay have confirmed that the original URL the eCart used, https://test.sagepay.com/Simulator/VSPFormGateway.asp, is no longer in use.
  ...but you might try:
HTTP Status Code: 500
HTTP Status Message: The request was unsuccessful due to an unexpected condition encountered by the server.
Error Code : 3098
Error Description : The VPSProtocol value is not supported by the system in use.
I'll contact Sage Pay again and find out which URL is correct.
Thank you.
NJ
I've double checked with Sage Pay and now have the correct URL for their test server. We've run a successful test transaction to Sage Pay albeit we can't get a Shipping charge applied (which we're discussing in another post so I won't reiterate that any further here).
Getting back to the billing and delivery address sections though...
I've re-run the eCart Checkout Wizard and ticked the "Include shipping fields on checkout page". I now have a billing and delivery form but there are problems with it...
http://www.nathonjoneswebdesign.co.uk/whiskybroker/buy-whisky-online-Scotland.php?wbid=25
If you add the above item to basket and proceed to checkout, enter your billing details the first problem is that if you untick the "Same as billing" checkbox it doesn't remove the billing address information. Should it?
Second issue is the formatting of the telephone number. Phone numbers could be from all over the world so trying to restrict it to a US format doesn't make a lot of sense to us. How do we edit/remove the validation for each field?
Third issue, if you have previously filled in a form in your browser and it makes a suggestion when you're trying to fill in the WebAssist forms, when you select a value from the drop down list of options that appear below the form field, and it's inserted into the field as your value, the jQuery validation pops up!
NJ
The checkbox is not supposed to clear the shipping or billing information when unchecked, so it is functioning as designed.
You can remove the formatting code from the phone number fields directly on the checkout page, just remove the pattern="" portion and the onblur events that do formatting.
I'll look into the suggestion issue filling forms. What browser did that happen in? I'm doing that now and don't see the validation messages.
Ok, I assumed unticking the box would remove the details.
Is there a way to edit the formatting code rather than just manually removing the pattern portion? For example, I need a telephone number to be entered so there need to be some kind of validation on it.
It was Microsoft Edge.
Thank you.
NJ
It will still require the field, just won't force a US format if you remove the pattern. With all of the variations on phone numbers across the world it would be difficult to find a pattern to encompass them all, but you can look on a site like: http://www.regexlib.com
That sounds like it may be a bug in Microsoft Edge. Microsoft Edge is still basically in a beta stage and can have issues that Microsoft will be resolving before the formal release when it eventually replaces IE.
