jQuery validation
Thread begun 8/09/2015 8:17 pm by Jason | Last modified 8/11/2015 11:02 am by Ray Borduin | 1258 views | 3 replies |
Jason
jQuery validation
I used the jQuery validation tool under Webassist/Forms but the form still submits. The validation balloons popup, but the form still submits.
Do you have a url where I can view the page live? It is probably an issue with another javascript file on the page that I'd have to debug live in context.
Jason
Private message
It looks like you have multiselect lists on the page named with brackets (which is correct, they need to be in php). When you are using form elements named with brackets you are required to give them a unique ID in order to use our JQuery form validation. I think if you add a unique ID attribute to any form element named with brackets it should start working properly.
