Variable feature from MySQLi create recordset wizard does not work anymore. Javascript error.
Thread began 8/08/2015 9:01 am by anonymous | Last modified 8/31/2015 11:53 am by Ray Borduin | 683 views | 2 replies |
anonymous
So removed the deprecated server behaviours extension i got through DMX Zone. I removed both DataAssist and MySQLi Server Behaviours. I reinstalled both DataAssist and MySQLi Server Behaviours. Now I no longer see my session variables or my list of databases. Now I cannot create a variable when I create a recordset. I get the error pictured below.
I loved my databases tab because when I put names to form fields I just dragged and dropped the name into the name="" part and then went over to bindings tab and drag and drop the same into the value="" part.
You need to install the Deprecated Server Behaviors for it to work properly. Both Data Bridge and MySQLi server behaviors depend on functionality only added with that extension. Please try installing that and this error should go away.
anonymous
Did that and it fixed the issue thanks
