rsobj.php Does it change?
Does the rsobj.php file change every time you add or edit a query?
No. It is a library file that may only change when a new version of the extension is released and installed.
Thanks Ray, I only work in Linux anymore, and working on something made with mysqli extension, so wanted to make sure I could still write code that would work.
