Shipping Session not Clearning on Shopping Cart Page...
Thread begun 8/06/2015 9:33 am by sfranzken73972 | Last modified 8/10/2015 11:48 am by Ray Borduin | 2711 views | 5 replies |
sfranzken73972
Shipping Session not Clearning on Shopping Cart Page after you clear the cart button
I'd just remove the shipping line from the cart page so that it isn't displayed since it won't be recalculated until they fill in the checkout form.
You can clear the shipping session variable on the checkout success page to clear it after a purchase has been made. If you don't have user login then you can probably just clear the entire session with:
session_destroy
Just place that right before the </body> tag on the checkout success page. If you do have user login and don't want to have them logged out, you can remove individual session variables with:
unset($_SESSION['YourCartName_UPS_Quote']);
The correct variable name depends on the shipping provider and cart name you are using. You can look it up from your eCart definition file for what is used to calculate the charge.
You can add two shipping rules with conditions based on the weight so that UPS shipping charges only are used if the total weight is over a certain value then add a separate rule for setting the shipping charge if the weight is under that value.
sfranzken73972
Shipping Rules Questoin
That is correct.
This could easily be done in a single premier support ticket. I think you have my skype contact information, just message me there if you want to finish this that way.
sfranzken73972
Session destroy did not work
See private message to recreate error.
I would just remove the shipping row from the shopping cart display on the cart page. Shipping isn't calculated until the checkout page, so any value displayed there won't reflect any updates made to the cart.
The session destroy is on the checkout success page, so by not proceeding to that stage the session destroy code doesn't run.
