deleting item
Hey Ray
The attached product_results.php page isnt deleting - the progress spinner shows but the item isnt deleting.
After the progress spinner finishes, the url looks like this: /admin_cms/product_results.php?ProductID=
Cheers
Jamie
Hey Ray
Cheers
Jamie
It appears that it would work to me. Do you have a url where I can view the page?
The hidden form element with id="WADADeleteRecordID" somehow got moved outside of the <form> tag and is after the </form>. Move it back into the form and the delete should start working again.
hmmm sorry bit confused as it seems to be that way already
</div>
</fieldset>
<input type="hidden" name="WADADeleteRecordID" id="WADADeleteRecordID" value="<?php echo($row_WADAproducts["ProductID"]); ?>" />
</form>
I think maybe the tags:
</body>
</html>
in the middle of the page on lines 633-534 may be throwing it off. The browser isn't recognizing the hidden as part of the form, and that might explain it.
You have a form nested inside of a form... that isn't valid in HTML.
You have to move your search form outside of your results page form.
doh not sure how I managed to move that main form opening tag above tjhe search form.... moved it back below and working fine
as ever thanks a million
