jQuery Footer
Thread begun 7/27/2015 11:49 am by Daniel | Last modified 7/29/2015 2:44 pm by Ray Borduin | 1154 views | 2 replies |
Daniel
jQuery Footer
Hi.
What I'm trying to do is:
1. I have a search attribute on the website that I'm developing and then a results page for the search that I'm doing.
2. Now there are 2 things that I want from the results page:
2.1 If the results information that is being displayed is smaller than the page, I want the footer to be right at the bottom of the screen.
2.2 If the results that is being displayed is more/or bigger than the screen I want the footer to be pushed down beneath the last result that is being displayed.
I've tried to research it but cannot find a answer and have a deadline that is coming up.
This is what the script looks like that I'm currently using:
<script language="javascript">
// Window load event used just in case window height is dependant upon images
$(document).ready(function() {
var footerHeight = 0,
footerTop = 0,
$footer = $("#footer");
positionFooter();
function positionFooter() {
footerHeight = $footer.height();
footerTop = ($(window).scrollTop()+$(window).height()-footerHeight)+"px";
if (($(document.body).height()+footerHeight) < ($(window).height())) {
$footer.css({
position: "absolute"
}).animate({
} else {
$footer.css({
position: "static"
$(window)
.scroll(positionFooter)
.resize(positionFooter)
</script>
Thank you very much
It seems like it is probably close. This is something we could help with in a premier support ticket.
I see that it is moving the position to absolute onload when it shouldn't... so it is getting into the if statement:
I'd add an alert below it that has:
alert($(document.body).height() + "\n" + footerHeight +"\n" + $(window).height());
See if you can figure out which of those numbers isn't being calculated correctly and why it is getting into that If statement when it shouldn't be.
Daniel
Okay thank you Ray.
I will give it a go. Thank you for your help I appreciate it allot.
