Extension updates are ready for installation on DW CC 2015
Thread begun 7/27/2015 8:56 am by Ray Borduin | Last modified 8/24/2015 3:53 pm by Ray Borduin | 11920 views | 9 replies |
Some users are still having issues getting the extensions to install because of bugs in the Adobe extension manager. Here are some tips that others have used to get around these issues:
1) Sometimes completely uninstalling and reinstalling both Dreamweaver and the Extension Manager causes it to start working.
2)
if extension manager did not show dw cc 2015, just delete ExMan.db. location is:
mac:
/Library/Application Support/Adobe/Extension Manager CC/Configuration/DB/
win:
C:\ProgramData\Adobe\Extenson Manager CC\Configuration\DB\
3) Some users have reported more success using the DMXZone extension manager:
http://www.dmxzone.com/go/22670/dmxzone-extension-manager-for-dreamweaver/
4) You can also install extensions directly through the command line without using an extension manager: https://helpx.adobe.com/x-productkb/global/installingextensionsandaddons.html
PatriceWebAssist
I spotted this on another list: http://zxpinstaller.com
I haven't tried it, since I haven't gone to CC.
doug425125
WebAssist Extensions Installer Development?
Hi Ray
Thanks for the information. It seems many extension developers are creating their own installers. Will WebAssist be developing its own installer for the WebAssist extensions?
Thanks,
Doug
Solution #3 ( DMXzone extension manager ) did not work for me. iMac OS X 10.10.4 Dreamweaver CC 2015 I have all the WebAssist extensions.
UPDATE: After removing Adobe Extension Manager & DMXzone Extension Manager and then re-installing both Adobe Extension Manager and DMXzone Extension Manager, I was able to install all WebAssist extensions with the DMXzone Extension Manager.
I'm not sure what the procedure would be when we need to update the WebAssist extensions in the future now though..?
We will if we feel it is necessary. As long as there are free and viable options out there then it will probably remain a pretty low priority.
MBrem
Solution 3, the DMX installer worked for me. Thank you for posting that.
Jediha
I completely uninstalled dw 2015. And ext. manager.
then reinstalled both.
Then installed WA extensions (design extender, databridge and mysqli )
Start DW 2015 and ... get this small window telling meit's installing data Bridge with a 1 - 2 - 3 sign.
But it keeps for ever saying: downloading files...
Can't use dreamweaver, can't use the extensions?
Before this I also tried to install with dmx zone installer. Installs just fine, but then after opening DW 2015 got the same 1-2-3 window for ever.
Before that I also tried the commandline installer. Installs just fine, but same 1-2-3 window forever.
Another couple of hours lost because of this stupid problem. I'm not very pleased, but also not sure if I am to be angry at Adobe or Webassist. (or myself if I saw something wrong...)
Is there someone who can shine his or her light on the case??
System: mac Pro, Yosemite, DW 2015 installed
EDIT/UPDATE:
I've looked up the network activities with this 1-2-3 popupwindows is active and I see that indeed DW is downloading files from webassist.com
BUT at a very slow speed (80 KB/s) So that is probably the reason the windows stays there forever. I will now just wait to see how long it takes to download whatever it needs to download.
@webassist: could it be that your fileserver is slow?? My internet connection is 14MB/s download and is working fine.
I just tested and it downloads relatively quickly for me, so I don't think it is an issue with our server. I'm not sure why your download would be so slow. I'm not even sure what the settings might be that would cause that. I haven't run into anyone with that issue before.
I could send you the install files and walk you through manual installation if it downloads that slowly it doesn't make sense to wait. It has to be a setting or other installed software causing the problem, but I'm not sure how to debug it.
If you post a US phone number or skype contact information I can call and look into it with you and help you with a manual install.
Jediha
Hi Ray,
thank you for offering support, but I just let it ran, and had dinner :-)
After dinner I found out it had finished (nearly after 2 hours). All works well. This was in DW 2014.1
This morning I installed the extensions for dreamweaver 2015. After starting DW again the 1-2-3 popup became visible, but this time the downloading and installing of files went quick and easy. After restart DW all was well!
Not sure what caused the problems yesterday (because then I also tried installing in DW 2015 with no succes).
Anyway, I can go back to work now and be happy.
Thanx.
Hans
juergen
AFTER INSTALLING VIA DMXZONE
after installing the extension with extension manager from dmxzone i had now an icon with WebAssist.
when i open a php site and klicking on model database i got an error please open a php document in order to use this interface
but i opend a php document
Make sure you have also installed the "Deprecated Server Behaviors" extensions available from Adobe. I think if you don't have that installed it could cause the error you describe.
Also make sure you have a site defined and the php page you have opened is saved to the site.
