Problem comma
Thread begun 7/25/2015 12:51 am by J7HNW | Last modified 7/27/2015 1:05 pm by Ray Borduin | 2211 views | 6 replies |
J7HNW
Problem comma
Hi
My cart is functioning perfectly - but on the checkout page it is putting a comma in the figure
It is set to take a 30% deposit with order as you can see
<input name="amount" type="text" id="amount" value="<%=WA_eCart_DisplayMoney(WA_eCart1, WA_eCart_GrandTotal(WA_eCart1) * .3)%>" />
When it transfers to my payment provider - it has a comma in it which causes a problem
Is there a simple way to remove the comma from the string of code above please ?
John
Use:
<input name="amount" type="text" id="amount" value="<%=number_format(WA_eCart_GrandTotal(WA_eCart1) * .3,2)%>" />
J7HNW
Aha it doesn't use PHP this site is an older site using ASP. Is it possible to send me the code to use on an ASP page please ?
<%=FormatNumber((WA_eCart_GrandTotal(WA_eCart1) * .3,2),,,,0)%>
J7HNW
This gives a 500 internal server error
My old working strong ( with comma ) was:
I have changed it to
<input name="amount" type="text" id="amount" value="<%=FormatNumber((WA_eCart_GrandTotal(WA_eCart1) * .3,2),,,,0)%>" />
Any ideas please ?
Thank you
John
I see, I left some code I should have removed. I think it should be:
<input name="amount" type="text" id="amount" value="<%=FormatNumber((WA_eCart_GrandTotal(WA_eCart1) * .3),,,,0)%>" />
If that doesn't work, what if you just used:
<input name="amount" type="text" id="amount" value="<%= Round((WA_eCart_GrandTotal(WA_eCart1) * .3),2) %>" />
J7HNW
Thanks Ray
This worked perfectly
You are a star
Thanks very much
John
