debugSQL(); for update query
Thread begun 7/21/2015 3:06 pm by P | Last modified 7/24/2015 1:03 pm by ivanibarra999361583 | 2492 views | 4 replies |
P
Hello,
I am unable to find debugSQL(); for update query.
However, it works with "RecordSet"
>> echo $RecordSet->debugSQL(); // works good
>> echo $UpdateQuery->debugSQL(); // DOES NOT WORK?
Please see if you can help.
Regards
That function isn't currently available for the query object class. They are so similar, that it might work if you just copied the debugSQL function from the rsobj.php file and pasted it into the queryobj.php file.
P
Please advice. I get following error when i echo >>
Error: Warning: substr() expects parameter 1 to be string, array given in {filePath}\queryobj.php on line 227
Content of link 227 is " $thisType = substr($paramTypes,$x,1); "
Thank you once again.
FULL CODE IS BELOW:
// ps_com starts
public function debugSQL() {
$debugStatement = $this->Statement;
$paramTypes = $this->ParamTypes;
for ($x=0; $x<sizeof($this->ParamValues); $x++) {
$pos = strpos($debugStatement,"?");
if ($pos !== false) {
$debugStatement = substr_replace($debugStatement,(($thisType=="s")?"'":"") . $this->ParamValues[$x] . (($thisType=="s")?"'":""),$pos,strlen("?"));
return $debugStatement;
// ps_com ends
Change the line:
To:
$thisType = $paramTypes[$x];
P
Appreciated. It's working..
thanks and have a good time..
