Conditional Statement with MySQLi
Thread begun 7/20/2015 2:13 pm by Steve | Last modified 7/20/2015 4:17 pm by Ray Borduin | 1376 views | 2 replies |
Steve
Hello,
Why does this fail:
<?php if (!empty($Location->getColumnVal("image"))) { ?>
When this works :
<?php if ($Location->getColumnVal("image") <> "") { ?>
Prior non MySQLi worked fine with the !empty identifier.
<?php if (!empty($row_rsLocation['image'])) { ?>
I found the answer on the php site: http://php.net/manual/en/function.empty.php
It says:
  Note:
Prior to PHP 5.5, empty() only supports variables; anything else will result in a parse error. In other words, the following will not work: empty(trim($name)). Instead, use trim($name) == false.
Since MySQLi is object oriented and uses Classes and Methods, empty() won't work prior to php 5.5. It appears this issue has been resolved in more recent versions of PHP and will begin working again.
Steve
Thanks Ray!
