Problem with arrays
When I create an insert or update behaviour for an array, I get
$InsertQuery->bindColumn("uitrusting", "s", "".((isset($_POST["uitrusting"]))?implode(",",$_POST["uitrusting"]):"") ."", "WA_DEFAULT");
This is correct, but when I go back to the server behaviour, I get a message that says
"It appears that one of your server-side values is improperly coded. Please check this interface for inconsistencies"
Click OK and OK will change the line to
$InsertQuery->bindColumn("uitrusting", "s", "\".((isset($_POST[\"uitrusting\"]))?implode(", ",$_POST["uitrusting"]):"") ."", "WA_DEFAULT");
I am sorry to do this to you while you are working on to update the other extensions to use MySQLI, and it took me a while to pluck the courage to post this anomaly. But it does need to be fixed.
