Add to Cart button not working after styling page —and possibly after adding product category menu
Thread begun 7/13/2015 8:47 pm by beaded | Last modified 7/13/2015 11:15 pm by Ray Borduin | 1925 views | 3 replies |
beaded
A formerly working products_results page and products_details page no longer have the Add to Cart buttons working after adding CSS styling —and possibly after adding product category menu.
I checked for blank lines between lines of PHP code, as described elsewhere in the forum, but no improvement after doing this.
Starting from http://www.lisascakestand.com/menu.html Choose "Cheesecakes" - a good choice, then "Moonstruck" variety.
Site entry configuration sent in private attachment.
Thank you.
I don't see an add to cart server behavior applied to either page. You need to replace those placeholder buttons with an actual add to cart button.
beaded
Okay. Thanks very much. This project was mothballed for quite a while, so I may be mistaken about what was done or not done.
Watch the webinar linked from your eCart 6 downloads page. It will have instructions on where to go from where you are. You are basically at the step just following running the Data Assist Wizard and before adding the Add to Cart buttons.
