How do i override shipping address so that Paypal uses the address on the site instead of the address on the paypal users file
Thread begun 7/13/2015 7:21 am by Solis Web Design And Hosting | Last modified 4/24/2018 1:39 pm by Ray Borduin | 7973 views | 33 replies |
We are setting up site using paypal express
You can add a parameter to the express checkout submission to prevent paypal from allowing users to update the shipping information from what you have passed in.
You can update the WA_eCart/PP_ECO_Scripts/PP_ECO_PHP.php file and update line 76 from:
"<LandingPage>Billing</LandingPage>";
"<LandingPage>Billing</LandingPage>".
"<AddOverride>0</AddOverride>";
that should do the trick.
I replaced the code and it still did not override the Paypal address on file
Please attach a current copy of your WA_eCart/PP_ECO_Scripts/PP_ECO_PHP.php file... depending on the version you are using I may have had you update the wrong lines.
here is the file you requested
I don't see the added code I referenced in this file.
update line 127 and add a line below it so that lines 127-128 read:
i added the code and it still doesn't override shipping...view image and also i included edited file
OK I think I made two mistakes.
First it should be: ADDROVERRIDE not: ADDOVERRIDE
Second, set the value to 1 not 0.
Please make those two changes and try again.
changed name by coping and pasting to the file and set the number to 1 and still the same results
Please attach a current copy of that file as well as the confirm.php page. I'll take a look and see if I can spot the issue.
