adding pages bassed template
Thread begun 7/13/2015 1:01 am by stuff223820 | Last modified 7/16/2015 9:51 am by Ray Borduin | 2579 views | 7 replies |
stuff223820
is there any way to create a new page using the template i am using form my installed PS site? Even if i create a blank php page and upload to my server, nothing shows I keep seeing this error:
Internal Server Error
The server encountered an internal error or misconfiguration and was unable to complete your request.
Please contact the server administrator, and inform them of the time the error occurred, and anything you might have done that may have caused the error.
More information about this error may be available in the server error log.
Additionally, a 404 Not Found error was encountered while trying to use an ErrorDocument to handle the request.
It should be possible. I'd have to look at the page to see what is causing the error.
I think I just talked to you on the phone and we set up a premier ticket to update your site together. We can look into this issue during that session to make sure you are able to create new pages.
stuff223820
Ray
Thanks for the help today
I tried to follow along with my notes but am missing some steps - can not get a 3rd menu to add to the top and on another note forget how to make the menu item in the custom menu disapear. (bikes) Also seeing an error on my menu.php file - see attachment
A new error popped up as well - see image
Please attach a copy of the page.php file and I'll take a look.
also add a copy of the menu.php file giving you errors.
stuff223820
pages sent
I fixed the issue with the pages.php file on your site.
I think the error on the menu page was just that you were accessing it directly and that page is meant to be included from your template onto an existing page.
open up the custom_pages.php page and you will see where bikes was removed and you can use that syntax to remove others (on line 35).
stuff223820
Thanks a ton Ray!!
