wa_setting spry_args duplicate error
I am installing PowerStore3 on a private web server on GoDaddy using MySQL5.5. I have an existing ticket that says install/2.php is not launching so I could not use the preferred setup method. So I am trying to manually setup the database. I tried to import the updated 10/6/2010 version of the sql database setup (db.sql). When I do this the import crashed when setting up the the wa_settings, specifically "wa_setting spry_args duplicate error". The other tables therefore are not setup with the provided script. Will this be fixed if we get 2.php fixed or doe the script need to be updated?
