get usps shipping calculate
Thread begun 7/11/2015 11:48 am by Jedi | Last modified 7/13/2015 10:34 pm by Ray Borduin | 3164 views | 6 replies |
Jedi
I used the ecart6 checkout wizard and set up the usps information there. Somehow the server behavior for usps did not appear on the confirm.php page so I added it. I completed all fields (except the checkout success field and checkout failure field on this server behavior). Then I uploaded the confirm.php page again and ran a 1.00 live transaction with the weight being 64 oz for the live item. Everything went through and I was charged for the item plus sales tax. My issue is that the usps shipping quote never showed up on the cart and I did not get any errors. I received my receipt and I was charged only the 1.00 and tax and no shipping. How do I get the shipping to calculate and charge? I have checked with usps and the site is registered.
My products page is https://www.kicreativeplastics.net/products_results.php
You don't have a failure redirect set up for the shipping server behavior, that is why it is letting the order go through when the shipping calculation fails.
I'd run a transaction and then create a blank page with just this code on it:
@session_start();
var_dump($_SESSION);
You can then manually go to this page after viewing the confirm page, or set it up as the shipping failure page for debugging purposes.
When a shipping quote fails we store the information about the failure in the session. This will display that information that we can use to determine why it failed and find a solution from there.
Jedi
Thanks Ray. I did that and i did get a failure code. It seems to be that a destination zip code is missing. The problem is that this error is happening when I hit the checkout button on the cart page which is before the client is able to put in a destination zip.
See error code below:
Update line 215 to:
if (WA_getSavedFormValue('CheckoutWizard_Sharp_Default','Postal_Code_2')) {
and then try it again.
Jedi
Thanks Ray,
That improved but I still get a shipping error. I believe it looks like I might need to do something different with the type of packages selected. Not sure exactly what the code means.
Jedi
I changed the mail type from parcel to First Class and that seemed to work. The shipping is showing up after checkout.
Is there a way to have show the customer what their shipping charges are prior to checkout?
You can show them shipping charges as soon as you know their address. If you have people log in, then you can use the stored profile information to calculate shipping charges on the cart page instead of waiting for the checkout pages.
