Cannot Install CC2015
Thread began 7/08/2015 7:38 am by J7HNW | Last modified 7/15/2015 11:11 am by Ray Borduin | 1523 views | 6 replies |
J7HNW
Have just updated to CC2015 Dreamweaver as your extensions are now supposed to work
Have installed E Cart and Data Bridge OK but when trying to install design extender I get
" This extension cannot be installed, it requires Dreamweaver version 9 or greater "
I have tried deleting the wincache - but still no luck
Help please - it is the ZXP extension I have download for the new Dreamweaver
When I reboot the machine and open Dreamweaver - and try to use eg insert google map
I get this error ( see attached JPG )
It sounds like it is opening the older version of the extension manager. Make sure you have the Extension Manager CC version opened and that Dreamweaver CC 2015 is listed as an installed product in the extension manager and then the .zxp should install properly.
J7HNW
I installed the latest update using the Creative Cloud Icon - but no software is listed inside it ( Cannot see Dreamweaver ) ?
How do I add this ?
Try uninstalling and re-installing the Extension Manager... that is what ended up working for me.
J7HNW
Have uninstalled and reinstalled the extension manager
Nothing showing - see attachment
Someone posted this on another thread:
if extension manager did not show dw cc 2015, just delete ExMan.db. location is:
mac:
/Library/Application Support/Adobe/Extension Manager CC/Configuration/DB/
win:
C:\ProgramData\Adobe\Extenson Manager CC\Configuration\DB\
maybe that will work for you.
J7HNW
Yes it worked - all now fine on CC2015 - again thanks for your kind help
