MySQLi Server Behaviours Compatibility
Thread begun 7/03/2015 12:10 pm by braduhl | Last modified 7/12/2016 11:39 am by Ray Borduin | 4195 views | 5 replies |
braduhl
I am in the middle of programming for our new product website. I have all the latest up-to-date WebAssist Extensions loaded in Dreamweaver CC 2014.
I understand that Data Bridge is still not MySQLi ready, but it is it correct that Ecart is? I can probably get by with setting up my own admin pages, along with my Product & Product Detail Pages using your MySQLi extension, but desperately need the "Repeating Table" feature of Data Bridge (to work with MySQLi) for my Product Page display.
Any thoughts? Should I be waiting to use MySQLi? Any closer to the update for Data Bridge?
Any insight you can give me would be much appreciated...
Thanks!
Brad Uhl
ECart has been updated for MySQLi.
You could probably use the repeat region server behavior to manually do a repeating table with the MySQLi server behaviors.
We were delayed once again with the Data Bridge update for MySQLi when CC 2015 came out and broke a lot of our existing UI's. We should have the CC 2015 UI's ready by early next week and can go back to work on the DataBridge update, however it will still be several weeks before that can be completed.
braduhl
MySQLi Server Behaviours Compatibility - Part 2
Thank you for your very quick response Ray - I appreciate it. I understand what you guys must be up against.
In regards to the Repeating Table, I need to go both horizontally across for the products and then down - not sure of how I could pull this off with the Repeat Region Server Behavior only.
I also forgot to ask in my earlier post about how we are supposed to format the data bindings (currency format?) now that Dreamweaver yanked some much needed features from CC. The deprecated extension for DB did not add any back in - nor did I see any formats for your MySQLi extension in the Bindings panel.
Thanks again for your time...
Brad
You can manually wrap any number with the number_format function to format it: number_format([number],2)
We could help with a horizontal loop... probably just use a FOR loop. If you give me more details I can help you with the syntax.
braduhl
Data Bridge & MySQLi
Can you please give me an update as to the status of making Data Bridge MySQLi ready? It has been a while and thought I would check in - did not see any updates on the website.
Thanks a lot!
Brad Uhl
I'm making progress, but can't give a date yet. Sorry I can't give more information. A Dreamweaver update is coming out soon and a lot will depend on how much that sets us back, which is still relatively unknown.
