Is Powerstore the best solution?
Thread begun 7/02/2015 11:37 am by thinkdolphin | Last modified 7/02/2015 4:58 pm by Ray Borduin | 857 views | 1 replies |
thinkdolphin
My client is called Cosmic Images. They put celestial images onto mugs, cutting boards, trivets and other items. I was using Cartweaver for the cart but their needs are more than what the software, as is, can do. And I am not a programmer so I have no clue how to make the changes.
Anyway, what they want is for the user to pick an image option (there are many different outer space image to choose from) and have that image that matches that option appear.
Is it possible to do this with Powerstore? Or is there another solution like eCart? I want to be able to use the current site design. And the site is already hosted and live. www.cosmicimagesgifts.com (if you visit and view a product you can see all of the image thumbnails. It just doesn't look good and isn't user friendly).
I'd recommend Powerstore based on your statement: "I am not a programmer so I have no clue how to make the changes"
If that is the case and your are just doing this one site, then I'd suggest not buying eCart and use the $400 you would have spent on it for premium support instead and we can help you make the necessary adjustments to meet your needs.
