DataBridge server side include issues
Thread begun 7/01/2015 3:26 am by Mohammed Aji Wajiro | Last modified 7/06/2015 10:52 am by Ray Borduin | 4757 views | 6 replies |
Mohammed Aji Wajiro
I have three pages. The first page (registerNew.php) contains a registration form designed with form designer. It has a secure page rule which allows only certain users have access to it. Moreover, it has dataassist insert record behavior with one of the fields points to a sessionid of SecurityAssist(foreign key).
The second page (reprint.php) contains links for displaying a page that contains the data from the registered records that matches that sessionid (filtered).
The third page (register_student.php) includes both pages and display only one at a time based on a condition. If a record that matches the sessionid does not exists in the database, display the registration form or else display the page that contain the links for displaying the information. My main aim for making it as such is to deny access to the registration form if a person is already registered.
I tested the whole setup on my local server and everything works as expected. But when I deployed the site on my host and try to access the third page without login, it shows a kind of warning about a header which is already included in helper_php.php (something like so). But if I login before accessing the page it works fine. I definitely know the warning has to do with the sessionid of the securityassist.
What I did is create another page and point the login page to it if authentication is successful. On that page I used server redirect behavior with trigger of’ before page load’ and directed it to that third page and that did the trick for me. But the major problem I am having is that if a user submits the registration form I get warning with the following messages: ‘Warning: Cannot modify header information - headers already sent by (output started at /home/ramatpo/public_html/portal/register_student.php:76 and Warning: Cannot modify header information - headers already sent by (output started at /home/ramatpo/public_html/portal/register_student.php:76) in /home/ramatpo/public_html/portal/registerNew.php on line 228) in /home/ramatpo/public_html/portal/webassist/forms/persist.php on line 13’. I don’t experience all these on my local server. Any help, suggestion or workaround is welcome.
Thanks.
Can you attach a copy of the two pages? I'd want to look at line 76 of register_student.php and line 228 of registerNew.php and persist.php line 13. My guess is that you have extra line breaks in your code maybe as a result of your upload.
Mohammed Aji Wajiro
These are the files as requested. Thanks.
It looks like you are trying to conditionally include one of two pages in the body of another... but the two pages have session setting and redirects that can only be done above the page.
The solution is to use WebAssist Plugins instead of traditional require statements to include the page contents. That should fix the problem.
Mohammed Aji Wajiro
Can you please guide me on that cos i have no single idea on how to use WebAssist Plug-in to achieve that.
Use the menu item : WebAssist->Framework->Insert Plugin to add the two pages you currently have added with require_once().
Mohammed Aji Wajiro
It works perfectly now. Thanks.
