"No Recordset Found" when using Create Dynamic Array with MySQLi recordsets. Is this a compatibility issue?
Thread begun 6/30/2015 7:55 am by markhaynes75235 | Last modified 7/17/2015 5:25 pm by Ray Borduin | 6600 views | 9 replies |
markhaynes75235
The WebAssist > Create Dynamic Array dialog shows "No Recordset Found" when used in conjunction with MySQLi recordset server behaviors. Is this a known issue? Is there a workaround?
Thanks!
Yes, Dynamic Dropdowns has not been updated to work with MySQLi yet. It only works with traditional recordsets at this point.
Dave W
Any ideas on the timeline of this update?
It seems that at this moment in time most of the extensions won't work in MySqli
We are working on updating DataBridge now, but it will take several months because of the number of interfaces that interact with the database.
Dave W
Thank Ray,
I thought when all of extensions were rolled into two units (DataBridge & Design extender) that it was done to make life easier for us and for you. It seems that perhapes it wasn't such a good idea after all!
Now instead of getting updates for seperate extensions we have to wait until you have updated the combined extension.
Not happy!
There is good an bad to anything. It is true we could have started releasing updates to one extension at a time with MySQLi support, but Dynamic Dropdowns would have likely been later on that list. The worst part would have been incompatibility if people had older versions and installation order would become relevant again. Also the cost passed on to our customers would have been more as they would have to upgrade the 13 individual extensions instead of having a lower combined upgrade price.
I appreciate your frustration and apologize we haven't been able to get out an update sooner. We will try our hardest to get it done as soon as possible.
Dave W
Thanks Ray,
I do understand what you are saying and appreciate the time it takes to make updates.
I was a little annoyed as I use the dynamic dropdown for colours and sizes in a customers shopping cart and it is rather complicated as it chooses the sizes available depending on colour and stock. I am sure I will be able to hand code it, but it will take so much longer.
Thanks again for explaining things, and for your help when I have needed it.
Dave W
Hi Ray,
I am trying to convert the dynamic array in dropdown boxes to use with MySqli.
I have had reasonable success but keep geeting the error " Undefined variable: row_getResults in .......on line 106" and I can't seem to resolve it.
Can you help at all please my script as is, is below. It seems to be the first line that is causing the problem.
if ($row_getResults) {
echo "<SC" . "RIPT>\n";
echo "var WAJA = new Array();\n";
$oldmainid = 0;
$newmainid = $getResults->getColumnVal("colourID");
if ($oldmainid == $newmainid) {
$oldmainid = "";
$n = 0;
while ($getResults) {
if ($oldmainid != $newmainid) {
echo "WAJA[".$n."] = new Array();\n";
echo "WAJA[".$n."][0] = '".WA_DD_Replace($newmainid)."';\n";
$m = 1;
echo "WAJA[".$n."][".$m."] = new Array();\n";
echo "WAJA[".$n."][".$m."][0] = "."'".WA_DD_Replace($row_getResults["SizeID"])."'".";\n";
echo "WAJA[".$n."][".$m."][1] = "."'".WA_DD_Replace($row_getResults["item_size"])."'".";\n";
$m++;
if ($oldmainid == 0) {
$oldmainid = $newmainid;
$row_getResults = mysqli_fetch_assoc($getResults);
$n++;
echo "var getResults_WAJA = WAJA;\n";
echo "WAJA = null;\n";
echo "</SC" . "RIPT>\n";
You'll have to update that first line to refer to your MySQLi recordset: $getResults->TotalRows
You will have more lines to update too. You have to update the while loop.. to use: while (!$getResults->atEnd()) {
and
would be:
$getResults->moveNext();
any reference to $row_getResults will have to be updated like: $getResults->getColumnVal("SizeID")
Dave W
Thanks again Ray, that was a great help. I'll give that a try. Should be able to work it out now....hopefully :-)
