Two recordsets on one page - how to restrict one of those to not display the results shown in the other?
Thread begun 6/25/2015 9:16 am by Nathon Jones Web Design | Last modified 6/29/2015 11:08 am by Ray Borduin | 3425 views | 6 replies |
I have two news article recordsets on one page. The first I have set to display the latest 5 headline news articles.
I would like the another recordset to display the remaining news articles.
How do I prevent it from showing the initial 5? Articles are displayed in order of date posted.
Thank you.
NJ
iain331081
I had a similar requirement ages ago, which I assume is the same sort of thing - the homepage on the site had news articles on it, but with the most recent ones given more prominence, like this:
http://www.mphrp.org
The trick turned out to be to use one recordset, and then use some PHP to control which records you show in each section. So that example has this to show the main story at the top:
mysql_data_seek($WADAtbnews, 0);
$row_WADAtbnews = mysql_fetch_assoc($WADAtbnews);
CONTENT HERE
This to show the next three:
<?php for($i=1;$i<=3;$i++) { ?>
mysql_data_seek($WADAtbnews, $i);
CONTENT HERE
<?php } ?>
And these to show the two columns of the oldest news further down:
<?php for($i=4;$i<=6;$i++) { ?>
CONTENT HERE
<?php } ?>
and
<?php for($i=7;$i<=9;$i++) { ?>
CONTENT HERE
<?php } ?>
Hope that makes sense and helps.
You could also use a NOT IN clause to show results in one query and limit it to results that aren't shown in another.
Here's my first MySQLi recordset:
$rsTOP5NEWS = new WA_MySQLi_RS("rsTOP5NEWS",$csdbmysqli,5);
$rsTOP5NEWS->setQuery("SELECT newsID, newsdate, newstitle, newssummary, newsdelete FROM news WHERE newsdelete = 2 ORDER BY newsdate DESC");
$rsTOP5NEWS->execute();?>
This returns the top 5 news items (by date).
So how should my second MySQLi recordset look?
Not being familiar with PHP I tried this without success...
$rsRESTOFNEWS = new WA_MySQLi_RS("rsRESTOFNEWS",$csdbmysqli,10);
$rsRESTOFNEWS->setQuery("SELECT newsID, newsdate, newstitle, newssummary, newsdelete FROM news WHERE newsdelete = 2 AND newsID NOT IN $rsTOP5NEWS ORDER BY newsdate DESC");
$rsRESTOFNEWS->execute();?>
Hope you can help. Thank you.
NJ
Hi Iain,
It's not really prominence I'm looking for I just want to display the top 5 results in one recordset and the remaining results in another.
Not being familiar with PHP I'm lost with the example you've given there although I don't doubt that it works I'm just not sure how to convert it to my scenario where I'm using WebAssist generated MySQLi recordsets. See my other reply for details.
Thanks for any help offered.
NJ
You could just update the StartLimit for that recordset.
$rsRESTOFNEWS
$rsRESTOFNEWS->setQuery("SELECT newsID, newsdate, newstitle, newssummary, newsdelete FROM news WHERE newsdelete = 2 ORDER BY newsdate DESC");
$rsRESTOFNEWS->StartLimit=5;
iain331081
Hi Nathon - I am certainly no PHP expert, and would have found this solution on a forum, if not from Ray or Jason here.
Ray's solution is probably more elegant, and you might have got that working now.
But I think this is still what you are trying to do - maybe 'prominence' was a bad choice of word, but the idea seems the same, i.e. you are splitting the records into more than one group, based on a date.
So in my example, the most recent record appears on one place, the next few by date in another section etc.
I have attached a stripped down version of the page below, which has the code in the header with the SQL query, and the HTML / PHP in the body showing the sections.
Hopefully from that, or from Ray's solution you get it working as you would like.
