Modifying Shipping Charge Based Session Varible
Thread begun 6/25/2015 12:35 am by djellis267466 | Last modified 6/25/2015 11:18 am by Ray Borduin | 815 views | 1 replies |
djellis267466
I need to change the shipping charge based on a UK postcode. There will only be two rates of charge "normal" and then a higher charge.
I have built the logic for checking the postcode and determining which one should incur the higher change. I am then setting a session variable for these postcodes. If the session variable exists then the higher charge should be made.
For a number of reasons (happy to discuss in a private message) I want to the above by having an extra if statement in the eCart object. I am using the PHP below but this always gives the lower charge.
The session variable is called $_SESSION["remote"]. I have tried to ensure that the session variable exists before calling a page that displays the cart and allows the customer to confirm the transaction.
Can you see what might be going wrong ? Many thanks !
//eCart Rule DJE modified for remote postcodes using session variable
function WAEC_ShippingCharge() {
$totalCharge = 0;
if (((sizeof($this->Items) >= 1)) && ((isset($_SESSION['$_SESSION[\"remote\"]'])))) {
$totalCharge += 15.00;//Result
else {
$totalCharge += 7.50;//Result
return WA_eCart_FormatNumber($totalCharge, $this->ForceDecimalsC, $this->DecimalPlacesC);
//eCart Rule
It looks like in the field where it asked for the session variable name it you put: $_SESSION["remote"]
but it was expecting just the variable name: remote
it should just be:
if (((sizeof($this->Items) >= 1)) && ((isset($_SESSION['remote'])))) {
