Recordset paging and filter stop working when Add to Cart button is added.
Thread begun 6/22/2015 9:08 pm by pliogeo413133 | Last modified 6/23/2015 3:11 pm by Ray Borduin | 1538 views | 3 replies |
pliogeo413133
Hi, I have built an online store for a client www.thesecuritybloke.com.au and had myproducts_results.php page (constructed using data assist) working well with Recordset paging and URL filter. Client wanted an add to cart button so I removed the form tag just inside the progress wrapper tag and added the add to cart button using ecart. The items add correctly but when I now use the url filter it only shows first item in filtered list. Also, when i arrow page number forward I get same thing happening. Seemstyo be some sort of conflict with Add to cart php code and recordset filter but i can't work it out. See attached with and without add to cart button.
Can you please help?
Andrew
I don't see why they would conflict. If you give me a live URL where I can see the problem and FTP access I'll take a look.
pliogeo413133
Thanks Andrew. Credentials in private message.
There was a typo in the form action for the add to cart form:
htmlentites
should have been:
htmlentities
This is a bug in an older version of the eCart. If you reinstall the latest version this shouldn't happen any more.
