Warning: require_once(webassist/framework/library.php): failed to open stream: No such file or directory in /home/content/89/12643589/html/install_cms/serial.php on line 2 Fatal error: require_once(): Failed opening required 'webassist/framework/lib
Thread begun 6/22/2015 2:30 pm by info334556 | Last modified 6/25/2015 12:26 pm by Ray Borduin | 6069 views | 12 replies |
info334556
Warning: require_once(webassist/framework/library.php): failed to open stream: No such file or directory in /home/content/89/12643589/html/install_cms/serial.php on line 2 Fatal error: require_once(): Failed opening required 'webassist/framework/library.p
I am running Power CMS Builder and I am getting a couple of errors on the start of actually using it on the web? They are..
Fatal error: require_once(): Failed opening required 'webassist/framework/library.php' (include_path='.:/usr/local/php5_4/lib/php') in /home/content/89/12643589/html/install_cms/serial.php on line 2
What do I do?
Make sure you have uploaded the files referenced in the error... Maybe just re-upload the entire /webassist/ folder. It appears some necessary files haven't been uploaded to the live server that need to be there.
info334556
Framework file not found: Templates/install.dwt.php
This is the error message I am getting now,
Upload the /templates/ folder... How about upload the entire site, who knows what other files weren't uploaded.
info334556
I have uploaded the entire webassist folders again, these are the folders with subfolders that I have uploaded again...
webassist/
WADbSearch/
WA_ValidationToolkit/
WA_Globals/
WA_DataAssist/
WA_CMS/
Templates/
install_cms/
CSSMenuWriter/
Connections/
admin_cms/
I have uploaded all of the things that appeared when I first put the Power CMS Builder in to the website four times, this is becoming craze?
Do you have to take down all of the Extensions that you have archived?
I have taken all of the archived WebAssist.com programs out of the Extensions. I reinstalled Design Extender. I reinstalled the files on the computer website & then on the web. I am still having problems?
When I put in the address, http://www.projectmend.org/install_cms/, it goes through the first screen fine, the second screen, and finally messes up on the third.
I put the Dreamweaver CS6 page of, database.php with this email so you can look it over to see if I am doing something wrong?
This error implies the page: /install_cms/database.php hasn't been uploaded.
If you give me FTP access to the server I can debug more thoroughly to help get it working.
info334556
I will give you the FTP info in private...
Something is going on with your upload. I don't see /install_cms/database.php on the server.
There is a file: database.php.LCK locked file there, but not the file you need. What are you using to upload?
What is creating the .LCK version of all of your files? I'm not used to seeing those on the server, so it might be related.
info334556
Let me start with telling you this, I am not hosting the website, another company is. The website was using Adobe Conrtibute until I was going to update the website with, http://www.projectmend.org/new_website. The new website does not work with Adobe Contribute (AC), due to an error message that comes up in AC, I have no idea what that message is due to me not having AC. Why it locks some files, in Dreamweaver CS6, and some it does not, is a problem to me now that they tried to use AC on the website.
Do I need to do anything to the website it self or what?
I spoke with the host of the website and he has given me access to the hosting site. I will see what I can do, I will keep you posted.
Ok, I got through the install_cms, now I am getting this message on the admin_cms/index.php...
Warning: require_once(../images/installed.jpg): failed to open stream: No such file or directory in /home/content/89/12643589/html/WA_Globals/WA_Globals.php on line 59
Fatal error: require_once(): Failed opening required '../images/installed.jpg' (include_path='.:/usr/local/php5_4/lib/php') in /home/content/89/12643589/html/WA_Globals/WA_Globals.php on line 59
I uploaded a missing file and made a correction to WA_Globals/WA_Globals.php
It should work now, please download the file I uploaded to prevent issues if you accidentally overwrite it in a future upload.
